ArcGIS Pro 2.7 - Extent indicators not working
6108
01-06-2021 01:12 PM
KeithAddison1
I have a layout with two map/data frames setup in it, I can configure the extent indicators for the small keymap all I want but after screwing with all the options I could find, I still can't get the indicators to show up.  The frame that the extent indicator is pointing to (the source, purple below) is the template for a map series, the idea being to have the extent indicator change as you go through the series sheets, could that be a problem?  Can this even be done in Pro?
KeithAddison1
Thanks, I wasn't aware of that option.  It didn't help, but I deleted everything and recreated it in a new project and it works now.  Must have been some unknown bug or toggle somewhere in the old version.
AubriOtis
Hi!
If you change the Shape dropdown to Map Series Shape it should show the extent indicator, and update for each page. I hope this helps!
Cheers,
Aubri
Cheers,
Aubri
KeithAddison1
