ArcGIS Pro 2.6 Editing Error:
2194
08-07-2020 08:07 AM
StephanieShaw1
The only two things that have happened since I last edited City Limits are: I upgraded to pro 2.6 and we installed a new version of license manager.
1) I tried to edit city limits in an existing project map, it failed with error. I closed arc pro.
2) I restarted my computer, I created a new project with a blank map added parcels (SDE), cities (SDE) and Zoning (SDE). I could edit zoning but still can't edit cites, I tried to split and edit vertices. I am working in ArcGIS PRO, there is no such thing as an "editing session".
3) I am in the correct coordinate system, no error in the editing content panel
4) Edit status dialogue says the feature is editable.
Spilt and Edit Vertices Error message
Any ideas I haven't tried?
StephanieShaw1
KoryKramer
Esri Community Moderator
Hi Stephanie.  Can you provide a larger screen capture that shows the error messages?  It is impossible to read anything in the current screenshots.
Thank you
StephanieShaw1
StephanieShaw1
Scott_Harris
Hi Stephanie,
So far, I can't reproduce a problem like this. We would need more details about the feature classes, relationship classes, the database itself (versioning status), etc. Esri Technical Support would be best equipped to help narrow it down.
-Scott
