ArcGIS Pro 2.5: “create tin” tool doesn’t respect “environments” settings of “extent” and “mask”,
2302
05-04-2020 09:58 PM
JamalNUMAN
Legendary Contributor
I observed that the “create tin” tool doesn’t respect “environments” settings of “extent” and “mask”.
Is this by design?
Jamal Numan
JamalNUMAN
It appears that adding an input feature with “soft clip” type resolves the issue. But how can the TIN cover the whole study area?
Jamal Numan
DanPatterson
MVP Esteemed Contributor
Tin supports only a certain number of environments (look at the bottom of this link)
Create TIN—Help | Documentation
Did you perform a Delaunay or a Constrained Delaunay triangulation?
The outputs will be different.
You might also want to follow up with
Delineate TIN Data Area—Help | Documentation
to get the result you want
... sort of retired...
JamalNUMAN
My point here is: I wanted to know if the TIN can cover the whole study area.
For example, if the IDW is run, the following outputs can be obtained depending on the environment settings. The output can be enforced to cover the whole study area. Is this doable in case of TIN?
Jamal Numan
JamalNUMAN
I understand that IDW can extrapolate, allowing it to cover the entire study area, whereas TIN cannot.
Jamal Numan
