Arcgis pro fails to Publish a Geoprocessing service end with staging failed?
I am trying to publish the extract data task tool using arcgis pro, and I couldn’t figure out why it fails to Publish a Geoprocessing service end with staging failed, I followed the steps below:
- 1. I run the extract data task and completed successfully
- 2. The Arcgis server connection is set to administration connection.
- 3. No errors or warnings are found when analyzed.
Please note that I followed the same steps using arcmap 10.7.1, and all worked fine, what might be the issue here?
