ArcGIS pro 2.5.0 add data issue
1288
04-08-2020 06:10 AM
DavidPike
MVP Notable Contributor
I'm noticing a bug where a new file isn't being seen by pro to be added, I keep needing to close and reopen a project for it to be visible.
tried this for .csv and.xls and they are visible in arcmap 10.7.1
Robert_LeClair
Esri Esteemed Contributor
David - I think what you may be experiencing is a refresh issue that I've seen in AGP for quite some time. I tested both a *.csv and a *.xls file and can see/add both.  In the Add Data pane, go to the far upper right of the UI and click the circular arrow to refresh the Add Data pane.  You "should" see the *.csv and/or the *.xls file.
Robert_LeClair
DavidPike
That's the badger (Pro Noob) Many thanks for your help Robert.
