ArcGIS Pro: 2.4.2: In general, ArcPro has less performance than ArcMap,
55512
123
10-27-2019 11:42 PM
JamalNUMAN
Legendary Contributor
I observed that the ArcPro has less performance than ArcMap. This observation is related to all tools and behaviors
Jamal Numan
DanPatterson_Retired
that is up to date.... 2.5 is in Beta 2, which means it hasn't been released and is in final testing for release in January
JamalNUMAN
Hi Kory,
Correct. On the site there is 2.5 Beta 2 for download. However, the Pro says “the version is current”!
Any advice?
Jamal Numan
download it and install beta 2
KoryKramer
Esri Community Moderator
beta 2 is even nicer
BrianWade
Morning Dan, can I load beta while still keeping my version 2.4.2 active?
I would like to test it out but need 2.4.2 for daily production.
Noooooo
You are either in or not.
It is best to have an isolated machine for beta. You don't want a 'work' machine for this
MichaelVolz
Esteemed Contributor
Totally agree.  The Clone wars make installing a beta version onto a test machine critical, as you would not want to corrupt your python environment for your production machine.
MarkBockenhauer
The first time any GP tool is accessed there is a geoprocessing tools initialization that takes a few seconds (should only be a few seconds).  Each tool also may have an initialization time, depending on what the tool does.  Specific to Create Utility Network it reads in layers from the active map.
MattWilkie1
I believe the lag time related to number of layers is because the GP tool validator inspects each and every one for validity, testing that a) it exists and b) is the specified or necessary data type. This can be bypassed by going direct to an arcpy script, but that's only a time saver in a narrow range of cases.
