ArcGIS Pro 2.3.2 Partially Hangs when Editing
4332
6
07-06-2020 12:03 PM
EvanO_Keefe1
I have a user who, while editing in Pro 2.3.2, runs into an issue where the program hangs. What's interesting about this is that tools can be selected, windows can be opened/closed/rearranged, etc., but there is no response in the map view when trying to select features. We've made sure that features are checked on in the List by Selection and the List by Editing. Also, Pro cannot be closed without using Task Manager when this happens.
*****************UPDATE*****************
We are able to replicate this by splitting a line and then using edit vertices. Please see attached video.
(view in My Videos)
When it happens it's using about 5% of the CPU and about 2GB of Memory.
Has anyone else run into this and have you found a workaround/fix?
Software: ArcGIS Pro 2.3.2
System: i7 processor
500 Gb hard drive
16GB RAM
Windows 10
Radeon 530 Graphics Card
Thank you to anyone who can answer this!
Tags (3)
Scott_Harris
Hi Evan,
Regarding your update and video:
I noticed that you are activating the tools via a shortcut on the Quick Access Toolbar (QAT). Another user previously reported activation problems when using tools launched from the QAT. As I mentioned in the other thread, we are fixing this in a future release.
One workaround would be to make sure to open at least one tool, any tool, from the Modify Features pane first before launching the editing tools on from the quick access toolbar. The other workaround would be to use the Tools gallery on the Edit tab instead - you can add Favorite tools to it:
Let me know if this helps,
Scott
Scott_Harris
Hi Evan,
Without steps to reproduce, we really can't say if it there is a workaround. I can say that hangs that were found and reported to us since 2.3.2 have been fixed. The most current release is 2.5.2; however, 2.6 is coming soon.
If you can narrow down the repro steps, feel free to post them here and I can test further.
Scott
EvanO_Keefe1
Thanks Scott. I'll try and get him updated to 2.5.2, but it all depends on if it's approved or not for use! If we're able to replicate it, I will add to the question!
Evan
EvanO_Keefe1
Scott,
Please see the update! Thanks!
Evan
Scott_Harris
Hi Evan,
Scott
EvanO_Keefe1
Hi Scott,
Thank you for the response. It appears that the Quick Access Toolbar was the issue. We have not been able to duplicate it using the Tools gallery.
Evan
Scott_Harris
Hey Evan,
Good to hear you have a workaround. Expect a fix for the issue with editing tools launched from the Quick Access Toolbar in a future release of ArcGIS Pro.
Scott
