ArcGIS Pro 2.0 scale bar height
7974
13
08-02-2017 09:21 AM
JerryHobbs1
I would like to adjust the height or thickness of a scale bar in ArcGIS Pro 2.0. Can this be done?
2 Solutions
DavidWatkins
Esri Alum
Resizing the height of the scale bar using a property is not yet available in Pro. We do have plans to expand the scale bar properties pane and add this option, but it will come in a future release.
David
KoryKramer
Esri Esteemed Contributor
Look for this in Pro 2.2.
RickeyFight
MVP Alum
If you are talking in the layout look here:
Scale bars—Layouts | ArcGIS Desktop
JerryHobbs1
I don't see anything in the online help regarding the height or thickness of scale bars in ArcGIS 2.0. ArcMap has this functionality, but I can't find it (if it exists) in ArcGIS Pro.
AdrianWelsh
MVP Honored Contributor
Jerry,
Double click on the scale bar and it will bring up the properties on the right hand side (likely). From there you can select the drop down menu of whatever you need to change and change it in there
You can also do this by clicking on the scale bar and then clicking on the format menu that becomes available and choosing the item you want to format in the drop list at the top ribbon:
JerryHobbs1
I've done this, but the property for scale bar height doesn't seem to be here. In ArcMap it's simple to set the bar size (e.g. 3.5 pt - see below).
I don't see a similar scale bar property in ArcGIS Pro. Am I overlooking it?
MervynLotter
MVP Regular Contributor
Changing the font size of the text also changes the height or size of the
scale bar.
AdrianWelsh
Interesting, I cannot find that either. So you just want to make that bar bigger and nothing else, right? The only place where I can see this is in the Format ribbon bar you can adjust the line width (but this does not change the bar size).
MervynLotter
I generally use the panes to do this, not the menu bar. Right-click on the scale bar and open properties. Then click on text and there one can change the font size.
RickyReid
I was hoping for more of a dynamic solution like an ArcMap.  Just click and drag a corner to resize and everything adjusts to the size of the frame.  It looks like there are options for that but it doesn't work properly.  I can resize the frame and everything stays the same size and leaves a bunch of white space in the legend (for example).
DavidWatkins
Esri Alum
David
