ArcGIS Pro 1.0 crashing constantly
11194
16
02-23-2015 01:09 PM
JanicePerez
ArcGIS Pro 1.0 has been crashing constantly. I do not notice any notable workflows causing it. It happens while I'm doing any and everything-- from just turning off or on a layer to simply changing text to just switching between map tabs. Here is the error I receive:
Problem signature:
  Problem Event Name: APPCRASH
  Application Name: ArcGISPro.exe
  Application Version: 1.0.0.1808
  Application Timestamp: 54c13b1e
  Fault Module Name: DX11System.dll
  Fault Module Version: 11.0.0.1808
  Fault Module Timestamp: 54c13cae
  Exception Code: 80000003
  Exception Offset: 0000000000010e06
  OS Version: 6.1.7601.2.1.0.256.48
  Locale ID: 1033
  Additional Information 1: 1f44
  Additional Information 2: 1f44a4c1109c0fcf146724c418e94ebd
  Additional Information 3: 133f
  Additional Information 4: 133ff95ab0df2c02308c9d787c59fbfb
Anyone have any ideas what may be causing this? The crashing has made this software near impossible to use.
JanicePerez
Hi Jeremy,
I'm not quite sure where to find this information. I do not see in the option screen where I change to OpenGL. Can you guide me?
Janice
JeremyWright
in your original email you listed the contents of the crash dialog (including "Faulting Module")
My question is: when you switch to OpenGL and it crashes, what is listed on the crash dialog?
JanicePerez
Hi Jeremy,
When the program crashes, I am not getting the same crash screen as I used to. I downloaded the error report (dmp file). Is it possible to send that over to you?
Janice
JeremyWright
can you share a screenshot of the new crash screen you're seeing here?
please send the DMP with a tech support request via email - [email protected] and it will go through triage there.
JanicePerez
See screenshot. I will send the DMP to [email protected].
JeremyWright
Janice,
As the message suggests please also email the dump to [email protected] so it gets added to the automated analysis system as well.
Regards,
Jeremy W.
Robert_LeClair
Esri Esteemed Contributor
Two options to assist with ArcGIS Pro crashing:
Delete C:\Users\<profile>\appdata\local\esri if there are performance issues.
Go to the manufacturers website for your video card and download the latest driver.  Windows Update will not do this although it says it does.
Hope this helps.
Regards,
Robert LeClair
Esri-Denver
