ArcGIS Pro 1.0 crashing constantly
11189
16
02-23-2015 01:09 PM
JanicePerez
ArcGIS Pro 1.0 has been crashing constantly. I do not notice any notable workflows causing it. It happens while I'm doing any and everything-- from just turning off or on a layer to simply changing text to just switching between map tabs. Here is the error I receive:
Problem signature:
  Problem Event Name: APPCRASH
  Application Name: ArcGISPro.exe
  Application Version: 1.0.0.1808
  Application Timestamp: 54c13b1e
  Fault Module Name: DX11System.dll
  Fault Module Version: 11.0.0.1808
  Fault Module Timestamp: 54c13cae
  Exception Code: 80000003
  Exception Offset: 0000000000010e06
  OS Version: 6.1.7601.2.1.0.256.48
  Locale ID: 1033
  Additional Information 1: 1f44
  Additional Information 2: 1f44a4c1109c0fcf146724c418e94ebd
  Additional Information 3: 133f
  Additional Information 4: 133ff95ab0df2c02308c9d787c59fbfb
Anyone have any ideas what may be causing this? The crashing has made this software near impossible to use.
JeremyWright
janice,
1.  Make sure you're sending in the error reports from Pro.
2.  Update your graphics card driver to the latest from the manufacturer, NOT from windows update.
3.  Try switching from DirectX to OpenGL if you're still seeing the problem after a driver update.
3.  Contact Esri Technical support for interactive assistance with the problem at any time.
Regards,
Jeremy W.
JenniferMcCall4
Could this possibly be an issue with the machine running ArcGIS Pro?  For instance, the recommended RAM is 8GB.  What are the specs of your machine?
JanicePerez
Hi Jennifer, Thanks for your reply. I have 8GB RAM on a 64-bit operating system with Intel Core i7-4700MQ CPU @ 2.40 GHz. Any ideas?
Also, I'd like to note that this is the only software on my computer that has this problem.
JeremyWright
janice,
Regards,
Jeremy W.
JanicePerez
Hi Jeremy, thank you very much for your response. Yes, I have been sending all my error reports to ESRI. I have also updated my graphics card driver and switched from DirectX to OpenGL. The crashing is actually less frequent now (from every 2-5 minutes to every 20-30 minutes). This has improved functionality but crashes are still common. I'll continue to send my error reports in to help ESRI improve their bugs.
KirstenPinkston
Esri Alum
Hi Janice,
You might also consider disabling your antivirus/ spyware as a test to see if there is any conflict there. If the crashing still persists, you can always reach out to Tech Support for more testing, but if not you can try adding ArcGIS Pro to the exclusions list of your antivirus software so you can run Pro going forward. I hope this helps!
Best,
Kirsten
JanicePerez
Hi ESRI,
The setting change from DirectX to OpenGL worked to provide me more functionality in ArcGIS Pro 1.0, i.e. less software crashes. However, I have since updated to ArcGIS 1.1 and now the crashing is constant. The setting change from DirectX to OpenGL actually makes it worse. No spyware detected and antivirus disabled. Do you folks have any other ideas as to why this may be happening? There is no specific work flow that leads to crashes. Anything I do basically crashes the program within a couple minutes.
Thank you,
Janice
JeremyWright
Janice,
Can you let us know the following?
1.  Make/Model of display adapter.  you can see this in device manager under "Display Adapters" section
2.  Driver version of display adapter.  This is in the PROPERTIES of the display adapter in device manager.
Regards,
Jeremy W.
JanicePerez
Hi Jeremy,
Thanks for the quick reply. Here is the information you requested:
Intel(R) HD Graphics Family- Driver version: 10.18.10.3412
NVIDIA Quadro K1100M- Driver version: 9.18.13.5306
Janice
JeremyWright
Thanks Janice.
OK, when you switch to OpenGL what "Fault Module Name" do you see?
