ArcGIS for powerbi
847
09-20-2024 06:59 AM
BibiObekpa
Hello,
I use ArcGIS in powerbi. I built a simple map viz using ArcGIS . i noticed when i open another page (sheet) in powerbi and i go back to the page where i have my map viz, the viz goes blank and i have to rebuild it all over again. I have tried to clear cache from my powerbi desktop, close and reopen powerbi but all this hasn't worked. I even tried a new powerbi workbook with a simple map using ArcGIS and still encountered same issue.
Please how can i fix this?
My version of power bi desktop is Version: 2.135.7627.0 64-bit (August 2024)
ShareUser
Esri Community Manager
Hi, thanks for letting us know. This is a known bug. You do not have to rebuild te visual again, you can try to (re-)add data to the (f.e.) colors field well, then the map should appear again. It is not ideal but it fixes it a bit quicker.
ShareUser
