ArcGIS Flood Impact Analysis Solution: Errors when analyzing roads and buildings
1120
07-20-2021 04:13 PM
AmandaBristowe
Here are the issues I am having. I did actually get all of these tools to run correctly the first time I did the analysis, but then I realized I inputted the depth and water surface elevation rasters in the wrong order when creating their respective geodatabases, so I ended up re-doing the analysis.
  • For both the Analyze Roads and Analyze Buildings steps, I am getting the following errors. I think this might have something to do with an invalid file path, but I'm not completely sure.
    Roads ErrorRoads ErrorBuildings ErrorBuildings Error
  • The second question I have is with creating the depth elevation rasters. The tool will run with warnings but doesn't create the depth elevation raster. I also get the same error whether I use a depth raster or not. Does anyone know what the correct inputs are for this tool?
    Creating Depth Elevation Raster ErrorCreating Depth Elevation Raster Error
    Thanks in advance for any help!
DanPatterson
MVP Esteemed Contributor
I am seeing ".shp" in you inputs/outputs.
Use copy features and copy any features into a locally stored file geodatabase and skip shapefiles for the analysis.  This could account for the errors
... sort of retired...
AmandaBristowe
Hi Dan,
If both the roads and buildings layer I am using are shapefiles, how do I go about fixing that?
Thanks!
