ArcGIS Deployment Solutions tool crashing ArcGIS Pro
1932
10-28-2019 11:36 AM
DanielLugo_Mercado
I have an issue working with ArcGIS Pro Deployment Solutions tool. All I do is open a new project, click on the Deployment Solutions tool and the program crashes in less than a second. What can be related to this issue? I am already administrator on the machine, I don't use any data, and I haven't been able to replicate the problem in other machines.
I'm attaching images of the issue.
KoryKramer
Esri Esteemed Contributor
What version of ArcGIS Pro and what version of the add-in do you have installed?
I guess that is the first thing to check.
Other than that, you could provide the .dmp file and we could analyze it to see if we can help determine a cause.
Go to C:\Users\<username>\AppData\Local\ESRI\ErrorReports and attach a few of the latest .dmp files from Pro crashing.  The filename contains a date-time stamp:
