ArcGis data replication using Oracle replication technologies
1269
03-28-2022 05:06 AM
MuhamedHarisMuhamed
Hi Support ,
We are using ArcGIS pro with Oracle database , and we are planning to have a new database server for web application to reduce the usage in production database , Kindly advice  Which is the best  solution for the replicate the real time data from production database to the application database .
Any one have experienced with Giodatabase synchronization with Oracle golden gate ?
regards
Haris Palliyal
AlisonWieckowicz
I see that this post is from 2022 but I curious what outcome you had when evaluating bidirectional replication of GDB with golden gate.   We too considering similar options.
There is a lot that concerns me with true bidirectional active/active replication of a geodatabase.  I was told that primary keys aren't required as long as you could uniquely identify a row.    How would global IDs be ensured to be unique if sde.next_rowid could be executed by either DB simultaneously.
Am I over thinking this?
