Arcade intersects featureSetByName not always returns result
3998
7
12-03-2023 06:06 PM
PierreloupDucroix
MVP Regular Contributor
Hello,
I have issues when trying to return a field from an intersecting polygon on points features. For some features it returns a result and for some others not. Here is my code :
// Value to copy from the intersected feature
var intersecting_field = "NAME";
// check existing value
var old_concession = $feature.CONCESSI;
if (isEmpty(old_concession) || old_concession == Null) {
// Create feature set to the intersecting class using the GDB Name
var intersecting_featset = FeatureSetByName($datastore, 'main.CONSESSION', [intersecting_field], true);
var intersected_feature = First(Intersects(intersecting_featset, $feature))
//console(intersected_feature.NAME)
// Check to make sure there was an intersected feature, if not, return the original value
if (IsEmpty(intersected_feature) || intersected_feature == null){
return;
// If the intersected feature is null, return the original value
if (IsEmpty(intersected_feature.name))
return;
var result = {
//result is a dictionary
"result": {
"attributes": {
"CONCESSI": intersected_feature[intersecting_field]
return result
I noted that including the geometry or not in the featureSet does not change the result, but I understand that this is a known bug, resolved in 3.2.
The polygons represent cities, so may have a large geometry.
Tested in ArcGIS Pro 3.1 in a UN mobile geodatabase, in popups and in an attribute rule.
[EDIT] I tried to debug, and found that count(intersected_feature) = 1. But even in this case, intersected_feature[intersecting_field] returns nothing...
CEO of MAGIS
PierreloupDucroix
I asked Esri support and thay created a bug : BUG-000167190 - Arcade expression for intersects does not find intersecting polygon's attribute within a bounding box.
It has been solved in latest version (pro 3.3)
CEO of MAGIS
jcarlson
Are you certain the intersecting features actually have values in the field? What about testing the expression against the objectid or globalid, just to see if it's an issue with the expression rather than the features themselves.
- Josh Carlson
Kendall County GIS
JohannesLindner
This is an expression for a Calculation Attribute Rule with the field parameter left empty (it returns a dictionary). If you want to use this in other ways (eg a popup or an Attribute Rule with a set field), you should return a single value.
Have you tried to return intersected_feature.NAME instead of intersected_feature[intersecting_field]?
Have a great day!
Johannes
PierreloupDucroix
Indeed, it is an attribute rule that I am now testing in the popup in order to debug.
I reworked the code as follows :
1st field :
var intersecting_field = "NOM";
var intersecting_featset = FeatureSetByName($datastore, 'main.CONSELEC', [intersecting_field], true);
return(count(Intersects(intersecting_featset, $feature)))
2nd field
var intersecting_featset = FeatureSetByName($datastore, 'main.CONSELEC', ["*"], true);
  return "Nope";
return intersected_feature.nom
3rd field is similar to 2nd but with return intersected_feature.globalid
But the result is similar.
Here you can view in action :
There are no overlapping polygons, and the intersecting polygon has a value in the field, but for some reason, sometimes the function finds an intersecting polygon, but just doesn't return anything...
CEO of MAGIS
PierreloupDucroix
Hello,
I made more tests, and now I am pretty sure that the issue is with the bounding box of the first polygon in the layer.
You can see in the previous image, that every point feature located in the second polygon, but intersecting the bounding box of the first polygon does not return the value.
If someone has encountered this or has a workaround...
So far I tried to delete/create spatial index, to copy features in another feature class, to recalculate spatial extent... Only the deletion of the first polygon resolve the issue... But of course I don't want that
[EDIT] I reproduced the bug in a simplified version :
I will contact the support team to log a bug
CEO of MAGIS
malte
I am dealing with the same issue right now, did you find a solution to this?
What is also weird is that for me, the rule works without problems when I edit directly on the sde. Once I publish the feature class as a feature service to Portal and edit over the feature service, the problems appear.
PierreloupDucroix
CEO of MAGIS
JohanWauters
This is a workaround in ArcGIS 3.1:
var lines = FeatureSetByName($datastore, "LineFC", ["attribute01"], false);
var intersectingLines = Intersects(lines, $feature);
var intersectingLine = null;
// Loop through the intersecting lines until a non-empty line is found
for (var line in intersectingLines) {
if (!IsEmpty(line) && line != null) {
intersectingLine = line;
break;
// If no non-empty intersecting line is found, return
if (IsEmpty(intersectingLine) || intersectingLine == null) {
return;
return {
"result": {
"attributes": {
"attribute01": intersectingLine.attribute01
