Arcade: for (var path of paths)
1048
03-04-2022 08:18 AM
Bud
Legendary Contributor
I'm attempting to use the JS from this post — in an Arcade calculation attribute rule: Code Review: Modify Polyline Vertices
That script uses the following for loop:
//This script works as standalone JS: https://jsfiddle.net/x4su7tna/
var paths = [[[0,5,null],[10,10, null],[30,0, null],[50,10, null],[60,10, null]]]
for (var path of paths) {
    return
ERROR 002717:
Invalid Arcade expression, Arcade error: Syntax error in for loop, Script line: 32760
I get that error when I try to save the attribute rule. I think the for loop is the culprit:  for (var path of paths) {
If I replace that for loop with  for (var path_idx in paths) {  , then I can successfully save:
    return
Question:
Why do I get an error when I use  for (var path of paths) {  ?
Tags (1)
jcarlson
In Arcade, the syntax of a for loop doesn't use "of", only "in".
- Josh Carlson
Kendall County GIS
