Arcade Expression - "Last_Value" Attribute Assistant Method
3704
03-12-2021 12:31 PM
by Anonymous User
Not applicable
I'm trying to write an arcade expression that will grab the last value used in a field and populate that same field on creation of a new record.  Also to have the rule only "fire" if the new record and its target field is saved on creation as null.
Basically a "translation" of the Attribute Assistant Method Last_Value into Attribute Rules.  I'm assuming there will be some use of loops, but honestly I just need some nudging in the right direction and help on how to construct this expression.
JoeBorgione
So your last value is a numeric value and when you add a new feature, you want that field to be last value + 1.  Is that correct?
If so, my suggestion is to use a data base sequence and start your sequence with the highest current value. You can then add  a rule to return the next value of the the sequence.
That should just about do it....
by Anonymous User
Not applicable
No, not looking for database sequences.  Totally good on that - generating IDs and all.
I'm talking about having a record on, say, a hydrant layer.  That I created yesterday.  All the fields are populated.    And then today I'm adding a new record and I want the Owner field to automatically grab the value of that record I made yesterday.  (So, the "last value" that had been entered in that field before my new record).
Appreciate any insights!
JoeBorgione
Ahhh.  I see...
Take a look here ; I see that last value currently does not have an attribute rule counter part.
JoeBryant1
I was surprised no one had created an Idea to get this implemented, so I did: https://community.esri.com/t5/arcgis-pro-ideas/attribute-rule-equivilent-to-quot-last-value-quot/idi...
Please upvote!
