Arcade Expression Help - If value in one field is NULL, then make the value in a different field a specific value.
5858
7
12-01-2023 10:46 AM
JamesBooth
I'm getting an error with the expression in the image above. I'm basically trying to set the UNIT value to be either a "Y" or "N" depending on the value of the UNIT_NUM field (UNIT NUMBER alias). If there is no values (NULL) in the UNIT, then I want the UNIT value to be "N", otherwise I want it to be "Y". Any help with my syntax is greatly appreciated. I'm new to Arcade! 🙂 Syntax is also written below in case image doesn't come through:
var a = $feature.UNIT_NUM
var b = $feature.UNIT
var c = "Y"
var d = "N"
return IIf(!IsEmpty(a), d,
else{return c}
2 Solutions
JamesBooth
Above did work thank you! The rule was validated and is accepted.
My only problem now is that when I saved the rules, all of my address points dissapeared! Every single one. But they are still in the attribute table! I have the symbology to be unique value, so it's not a symbology issue. I went back to my attribute rules and deleted that new rule, and the points reappear. Really strange!
In my Address points feature class, I have a large number of fields. Two of them are UNIT and UNIT_NUMBER. Many of my existing address points have values for the UNIT_NUMBER. Many of them however are also Null values. I want the existing addresses and any new addresses to auto-populate the UNIT field with a Y or a N. I want the UNIT value to be "Y" if there are is a unit value in the UNIT_NUMBER field. And I would like the UNIT value to be "N" if the UNIT_NUMBER is Null.
I'm really not sure why the new rule, which seems to be valid, would visually remove ALL of my address points. ESRI bug? Or am I just missing something obvious?
CodyPatterson
MVP Regular Contributor
Glad to hear it's working! That is very odd though, I'm not sure why it would remove all visual indications of what is occurring. As DavidPike mentioned below, you could try to use the calculate field expression if you aren't already, and here is another broken up section of what you could place in there with some pseudo code:
var unitNumber = $feature.UNIT_NUM;
if (IsEmpty(unitNumber)) {return "N";}
else {return "Y";}
CodyPatterson
I'm not sure if it'll be entirely helpful, but your IIf statement is missing an ending parenthesis, I believe it should be:
else{return c})
Could also try this:
return IIf(!IsEmpty(a), d, c);
I'm still looking into this though to see!
JamesBooth
CodyPatterson
else {return "Y";}
JamesBooth
JosephRhodes2 suggestion to alter yours slightly worked and my points didn't disappear! Thanks Joseph!
I'm having another issue now with the domain values set on the UNIT field of Yes or No. I perhaps accepted the solution too quickly lol! I will post another question. Thanks again
JRhodes
Oh shoot, I deleted my response because it looked like you had solved your issue already by the time I posted it. So here it is again for posterity:
var unitNumber = $feature.UNIT_NUMBER
var hasValue
IIF(IsEmpty(unitNumber), hasValue="N", hasValue="Y")
return hasValue
DavidPike
MVP Notable Contributor
is this calculate field?
JamesBooth
No this is an Arcade Expression set on a field within 'Attribute Rules', which I can get to by right-clicking on a feature layer and choosing Data Design > Attribute Rules.
