Arcade conditional color text label not working in Pro
2722
04-26-2022 05:18 PM
Jen_Zumbado-Hannibal
I have been trying to create an arcade expression base on the condition of an attribute. I'm on the latest 2.9.2 of ArcGIS Pro.
Here is my expression in label properties:
if(DomainName($feature, 'Private')=="Yes") {
return "<CLR red= '197', green= '0', blue='255'>"+ $feature.AssetId+ "</CLR>"
else {
return "<CLR red= '56', green= '168', blue='0'>" + $feature.AssetId + "</CLR>"
The first color is purple
The second is green
But instead, I get the actual code and not the color text I want. Plus, the colors are backward. Purple sewer cleanout should match RBG color purple for when (DomainName($feature, 'Private') == "Yes") or else when it's "No", RBG color should be green.
What am I doing wrong?
Jen Zumbado-Hannibal, GISP
GIS Coordinator
City of Forest Grove
Forest Grove, OR 97116
JohannesLindner
MVP Alum
Remove the commas inside the CLR tag.
I don't know your data structure, but from the screenshot it seems to be correct? The purple asset has an AssetID (1295), so it shows as green text. The yellow assets have AssetID "PRVT", so the labels are purple.
Maybe try using the actual field values instead of the DomainName.
Have a great day!
Johannes
JohannesLindner
MVP Alum
Have a great day!
Johannes
Thanks @JohannesLindner . Eliminating the commas worked great! I also corrected the symbology to match the colors. I had it backwards.
Thank you again! You saved me from banging my head against the wall 😉
GIS Coordinator
