Arcade code to specify fill colors
585
05-13-2024 09:26 AM
RobertBorchert
Honored Contributor
I would like to be able to specify the fill colors for features using Arcade Scripting
For example I use this script to change color for labels
var name = $feature.NAME
var scada = $feature.SCADA
var nopen = IIF($feature.NORMALP == 0, " ' ", "")
var ascheme = iif($feature.ASCHEME >"","<CLR green = '255'>" + $feature.ASCHEME + "</CLR>","")
if(scada == 0){return name + nopen + ascheme;}
if(scada == 5){return name + "<CLR green = '255'>" + " * " + "</CLR>"+ nopen + ascheme;}
I would like to use a similar procedure to specify the fill and outline color for symbols
In labels we can use things like BDG
