Arc Pro Export to AIX not properly exporting labels
407
04-07-2026 11:28 AM
Apormen
I am having issues when exporting maps with dynamic labels and callouts from a layout to AIX file. Exporting as basic text works for the labels, but when I add any type of callout or halo to the label, it does not export the text, only the graphic/callout. There are no clipping constraints on the layer, which has been a response I have seen in my limited research.
ESRI's chatbot says this is a known bug, but has anyone found a workaround?
Tags (4)
Ashley_kuhn
Hi @Apormen I will look into this issue. Could you please share which versions of ArcGIS Pro and ArcGIS Maps for Adobe you are currently running? If possible, also send the Pro project with the labels you are experiencing issues with.
