ApplySymbologyFromLayer toolbox Python script problem
4221
9
12-13-2022 04:27 PM
by Anonymous User
Not applicable
arcpy.management.ApplySymbologyFromLayer() works from a standalone script, or the Arc Python window, but NOT from a toolbox script inside a map session. It executes without an error, but it doesn't change the symbology.
The only possible reason I can see is that the object type is a little different for a layer depending on whether it's a standalone/python window or the toolbox script.
standalone/python window layer type: <arcpy._mp.Layer object at 0x000001C3E7390C10>
toolbox script layer type: <MappingLayerObject object at 0x000001AEA43E2270>
Does anyone know what's going on?? I have run into other weird glitches with ArcGIS Pro where tools function differently in toolbox scripts, and it's very frustrating.
Script example that only works if run as a standalone script:
Tags (3)
JohannesLindner
From the tool doc:
To see the symbology created in a script tool, the tool must include the layer as a derived output parameter.
Have a great day!
Johannes
DanPatterson
MVP Esteemed Contributor
Are you using a custom toolbox where you can specify the parameter type from a dialog or is this a parameter-less tool?  A toolbox script will behave properly if you define the parameters in the tool and select them from the dialog like this?
... sort of retired...
by Anonymous User
Not applicable
I was grabbing the layers through the map.listLayers() method because one of them will be an in-memory layer that I created in my script, not a user input.
But I just tried making them both user input parameters (Feature Layers), and it still didn't work.
JohannesLindner
From the tool doc:
Have a great day!
Johannes
by Anonymous User
Not applicable
Ahh, thanks! I guess I should have read the doc more thoroughly. I've been avoiding derived parameters, because I didn't understand them.
Here's the code that works.
by Anonymous User
Not applicable
Actually, I found a better solution for my purposes. I was having an issue with the derived output adding a second copy of the layer being affected, when that layer was an in-memory layer. When I changed so that it wasn't added to the map at all until the derived output from the symbology tool, then I realized that the derived output doesn't get added to the map until the script ends. This is a problem because I need to apply symbology, and then edit it within the same script.
Here's the new method that works better when your affected layer is an in-memory layer: no duplication, and immediately added to map.
I know this seems like a pointless script... it's just a fragment of a larger script.
MichaelPorter
This worked for me. Thanks!
MatthewSackrison
Thanks for posting! This fixed my issue, too, without needing to mess around with all the derived output stuff.
succip
A bizarre choice to require this implementation from Esri's end but your code worked. Thank you!
mody_buchbinder
Hi
More or less the same code works for me when I take the source layer from lyrx file and not from the TOC
