ApplySymbologyFromLayer_management inside toolbox script doesn't work
4115
9
08-20-2021 02:05 AM
dstrigl
Dear esri community,
I am rather new to ArcGIS Pro, but have really good experience with Python.
Now I created my first little toolbox with a script with takes an input feature layer and creates another output feature layer from the input by just taking a random sample of features from it.
This works fine, but now I also want to apply the same symbology from the input feature layer to the new created output feature layer.
Therefore I execute ApplySymbologyFromLayer_management at the end of the script.
This runs without an error, but doesn't update/change the symbology of the new created output feature layer.
Interesting is, if I call the same statement (ApplySymbologyFromLayer_management) inside the Python command prompt of ArcGIS Pro it works.
I also tried to execute the ApplySymbologyFromLayer_management command inside a second script of my toolbox, but this also doesn't work.
Anyone has an idea what's the problem?
Thanks and regards,
Daniel.
DanPatterson
MVP Esteemed Contributor
dstrigl
Thanks for your fast reply. Yeah, this could be the reason. Thanks! Than I have to wait until it will be fixed.
HannesZiegler
Hi dstrigl, could you try using this approach:
import arcpy
params = arcpy.GetParameterInfo()
inlyr = params[0]
outlyr = params[1]
res = arcpy.management.Copy(inlyr.valueAsText, outlyr.valueAsText)
outlyr.symbology = inlyr.valueAsText
Set your tool's parameters like this:
The above approach is described here and works in my testing.
Please let me know if this solution works for you!
dstrigl
Hi Hannes,
thanks for your response.
Sorry, but your solution doesn't work in my toolbox script.
Maybe, it's my fault because at the moment I am not so really familiar with the different types of Python scripts in ArcGIS Pro (.tbx and .pyt) and the different data types.
At the moment I have created my own little toolbox with the following Python code:
import random
import arcpy
class Toolbox(object):
    def __init__(self):
        """Define the toolbox (the name of the toolbox is the name of the
        .pyt file)."""
        self.label = "MyToolbox"
        self.alias = ""
        # List of tool classes associated with this toolbox
        self.tools = [SelectSampleByPercent]
class SelectSampleByPercent(object):
    def __init__(self):
        """Define the tool (tool name is the name of the class)."""
        self.label = "SelectSampleByPercent"
        self.description = ""
        self.canRunInBackground = False
    def getParameterInfo(self):
        """Define parameter definitions"""
        # First parameter
        param0 = arcpy.Parameter(
            displayName="Input Features",
            name="in_features",
            datatype="GPFeatureLayer",
            parameterType="Required",
            direction="Input",
        # Second parameter
        param1 = arcpy.Parameter(
            displayName="Proportion of sample (in %)",
            name="in_range",
            datatype="GPLong",
            direction="Input",
        param1.filter.type = "Range"
        param1.filter.list = [0, 100]
        param1.value = 10
        # Third parameter
        param2 = arcpy.Parameter(
            displayName="Output Features",
            name="out_features",
            datatype="DEFeatureClass",
            direction="Output",
        params = [param0, param1, param2]
        return params
    def isLicensed(self):
        """Set whether tool is licensed to execute."""
        return True
    def updateParameters(self, parameters):
        """Modify the values and properties of parameters before internal
        validation is performed.  This method is called whenever a parameter
        has been changed."""
        return
    def updateMessages(self, parameters):
        """Modify the messages created by internal validation for each tool
        parameter.  This method is called after internal validation."""
        return
    def execute(self, parameters, messages):
        """The source code of the tool."""
        in_features = parameters[0].value
        percent = parameters[1].value
        out_features = parameters[2].value
        in_catalog_path = arcpy.Describe(in_features).catalogPath
        feature_count = arcpy.GetCount_management(in_catalog_path).getOutput(0)
        count = int(float(feature_count) * float(percent) / 100.0)
        oids = [oid for oid, in arcpy.da.SearchCursor(in_catalog_path, "OID@")]
        oid_field_name = arcpy.Describe(in_catalog_path).OIDFieldName
        random_oids = random.sample(oids, count)
        oids_str = ", ".join(map(str, random_oids))
        sql_exp = f"{arcpy.AddFieldDelimiters(in_catalog_path, oid_field_name)} IN ({oids_str})"
        arcpy.Select_analysis(in_catalog_path, out_features, sql_exp)
        arcpy.management.ApplySymbologyFromLayer(arcpy.Describe(out_features).baseName, in_features)
        return
Maybe you see some errors inside the script?!
I would like to pick some samples (randomly from the source feature layer) and write it to another new output layer, together with the original symbology from the source layer.
Regards,
Daniel.
HannesZiegler
I just ran this toolbox and it applies the symbology to the output, what version of Pro are you working with?
dstrigl
ArcGIS Pro 2.6.5
HannesZiegler
Are you constrained to 2.6.5, or are you able to upgrade to a more recent version?
For 2.7 and greater you may also try arcpy.setParameterSymbology.
arcpy.SetParameterSymbology(2, in_features)
dstrigl
Hi Hannes,
thanks again for your response!
That's great to hear 🙂.
I have to verify and try to get an newer version. Afterwards I will try again and give you feedback.
Thanks and regards,
Daniel.
LeandraGordon
ApplySmbologyfromLayer is still very buggy even in 2.8.1
I can get some layers to work if I create the LYRX files from layers with a different name but not all of them
