Append Features From AGOL service to GDB
709
08-30-2022 10:32 AM
XavierRouxRacine1
Hello, I need to add feature from AGOL service to a GDB using the append function of Arcpy. I need to run that from a python script absolutely. Here is my line of code
result = arcpy.management.Append(Feature url , gdbPath, "NO_TEST", params, '', '')
It's work fine in ArcGIS Pro, but not when I run my python code. It's return me the error 00732.
Here are the error messages I got :
syntax error, unexpected WORD_WORD, expecting SCAN_ATTR or SCAN_DATASET or SCAN_ERROR
context: <html^ lang="en"><head> <title>Home</title> <link href='/ESRI.ArcGIS.SDS.REST.css' rel='stylesheet' type='text/css'> <link rel='SHORTCUT ICON' href='/favicon.ico'><meta http-equiv="Content-Type" content="text/html; charset=UTF-8"/> <meta name="keywords" content="ArcGIS REST Services Directory Root"></head><body><table width="100%" id="userTable" class="userTable"><tr><td class="titlecell">ArcGIS REST Services Directory</td></tr></table><table id="navTable" class="navTable" width="100%"><tbody><tr valign="top"><td class="breadcrumbs"><span id="homeBreadcrumbs"><a href="/0o8QNvTvT8ZVNsRw/ArcGIS/rest/services">Home</a> > <a href="/0o8QNvTvT8ZVNsRw/ArcGIS/rest/services">services</a> </span></td><td align="right"> | <a href="http://resources.arcgis.com/en/help/arcgis-rest-api/" target="_blank">API Reference</a></td></tr></tbody></table><div id="jsonLinkTable"><table><tr><td class="apiref"><a href="?f=pjson" target="_blank">JSON</a></td></tr></table></div><div class='restHeader'><h2>Home</h2></div><div class='restBody'><div class="restErrors">Token Required<br/></div></div></body></html>
arcgisscripting.ExecuteError: Échec de l’exécution. Les paramètres ne sont pas valides.
ERROR 000732: urlService doesn't exist or not take in charge
Échec de l’exécution de (Append).
Thank you for the help
RhettZufelt
MVP Notable Contributor
This is working for me to do just that:
import arcpy
arcpy.env.preserveGlobalIds = True
Signs = r'Database Connections\SignsDatabase.sde\SignsDatabase.DBO.Signs'
L0Sign = r"https://services3.arcgis.com/asdfsagasdfsd/ArcGIS/rest/services/hostedfeaturelayer/FeatureServer/0"
SignTable =  arcpy.FeatureSet()
SignTable.load(L0Sign)
with arcpy.EnvManager(preserveGlobalIds=True, scratchWorkspace=r"C:\SSA\SSA_project\Default.gdb", workspace=r"C:\SSA\SSA_project\Default.gdb"):
       Signs = arcpy.management.Append(inputs=[L0Sign], target=Signs, schema_type="TEST", field_mapping="", subtype="", "")[0]
R_
