Append cannot open data in Modelbuilder
1438
11-15-2023 10:44 AM
CarolineChanEEC
I'm working on a modelbuilder tool to append and update data. I have isolated an issue when the model gets to the append tool. I've isolated that portion of the model (just the tool with the inputs). It gives me
ERROR 000229: Cannot open D:\ProProjects\PFAS\Updates.gdb\xtabResultsHAtem_ExportTable
ERROR 000229: Cannot open GIS_DEP.PFAS_ResultsHA
 and then
Failed to execute (Append).
The input table is in a geodatabase, while the target table is in an enterprise geodatabase.
If I run the tool with the same inputs and settings from the geoprocessing window, it runs fine.  Any ideas?
lah
I'm getting this same "cannot open ..." error running the append tool with the Update Options - matching fields configured. If I remove the matching fields for update, the tool will run successfully; however, I need the data to update if the same record exists.
Did you ever figure this out?
