App freezing/slowing when I scroll contents pane items?
702
04-25-2024 12:14 PM
CHNArcGIS
I have a project that is behaving strangely, in ArcMap days I would have run it through the MXD Doctor or done a "save-as" into a fresh project, but not sure how to troubleshoot it in ArcGIS Pro.
The issue is that when i am scrolling in the contents pane I seem to hit a certain point and then the whole app slows to a glacial crawl.  I can switch to another map/layout tab and its contents pane works fine and I can click around, but switching back to the problematic tab still leaves the contents pane frozen.  If i quit the app and relaunch the project it sometimes solves the issue, sometimes not.  It is also not reproduceable as two days ago I had the behaviour on one of the layout tabs in the project and today i am having it in a different one.
Anyone else had this behaviour?
I am in V3.2.1 and downloading the update now to see if it hopefully solves this.
CHNArcGIS
I updated the app and still have the same problem.  Happens in a couple different template files accessing different items in the contents pane.
