align features
5873
13
07-16-2019 02:27 PM
EmilyBurson
How do I simply align the edges of two polygons in ArcGIS pro? I digitized them and the lines don't match up perfectly, but there must be a better way than to go and edit all individual vertices by hand.
Tags (1)
EmilyBurson
New to GIS with Pro. I have looked up how to use the align features tool and I can't seem to get the "Align" Button to activate.
MichaelVolz
Esteemed Contributor
Does the screen for the tool you are using look like this:
In this scenario I have 2 adjacent polygons selected and I then need to draw an alignment path that follows the border of 1 of the 2 polygons.  This is just an exaggerated example as I'm sure your polygons are not off by 2,000 feet.  After I draw a path and double-click to end the lines path I will see a polygon that shows the alignment area and the Align button should then be enabled.
edmeehan
Hi Emily, did you ever find an answer to this question? I recently encountered the same issue.
edmeehan
Hi Emily, did you ever find an answer to this? I am currently experiencing the same problem
