Alias Edits Won't Take
1231
07-02-2024 08:05 AM
DunnGIS
I was trying to edit the alias of several feature classes in the catalog pane since right clicking on the layer in the contents pane and trying to change the alias through properties doesn't seem to work. The property can be edited if I go to the feature class under its geodatabase, but when I hit okay to accept the change, it only saves up to the third character in the new string. For example, I type in "Storm" as an alias and the new alias is "S." If I try a second time, it may end up as "St" or "Sto," but never will it be the entire word.
BarryNorthey
A bit more tedious but try it from the Python Window where OspreyNests is the current FC name and Osprey Locations becomes the alias.
arcpy.AlterAliasName('C:/. . ./Practice.gdb/OspreyNests', 'Osprey Locations')
BarryNorthey
DunnGIS
Wow, that did it! Thank you so much!
I really need to invest some more time into developing my Python skills with Arc. Seems like it's so much more efficient at handling tasks than a lot of the baked in UI solutions.
