Address Inspector in ArcPro??
3788
6
10-26-2017 08:39 AM
RyanHartley
Simple question. Is there an address inspector in ArcPro yet?  If not, is there some sort of equivalent that allows someone to quickly identify an address using the locator file?
Thank you-
DanPatterson_Retired
Address inspector? Not sure what you are referring to, but this is what is available in Pro about finding an address
RyanHartley
I'm talking about the Address Inspector Command on the Geocoding toolbar in ArcGIS 10.5.  The button looks like a little house.  This command allows the user to click on an area near the street and it will return the address along the street tool-tip style.  Been standard with ArcGIS for years.  We use it to assign addresses to new construction.  Very handy tool.
XanderBakker
Esri Esteemed Contributor
I suppose you could use the Reverse Geocode—Help | ArcGIS Desktop if you have a list of locations (features) you wish to get the address for, but it is not the same as the Address Inspector. You could upvote this idea: https://community.esri.com/ideas/13741
ChristopherBertrand
Yes. There seems be now.  Click the drop down menu on the Locate tool on the Map tab.  The bottom tool is Address Inspector.
LillianMucha
Thank you!!!!! 😀
ShanaBritt
The Address Inspector tool is new for ArcGIS Pro 2.5. Holding the C key while the tool is active allows you to temporarily navigate in the map while using the tool. Identify addresses and places on the map—ArcGIS Pro | Documentation
