Adding values to landcover raster
857
01-30-2024 07:00 AM
momoreu
Hi Esri Community! I have a landcover raster that I created using supervised classification in ENVI (2005 version), however the raster created only has 6 values representing different fuels/vegetation on the landscape. I am interested in adding additional values to the raster file in order to then classify them as other types of vegetation found on the landscape that were not classified before (for example, instead of just having one forest value/classification, I can have two that distinguish deciduous forest from pine forests). Is there a way I could do this in ArcGIS Pro?
Thanks! 😊
DanPatterson
MVP Esteemed Contributor
You can't add values to a raster, you can change them, but it appears that you will want to go through the reclassification process again
Re: Adding values to landcover raster - Esri Community
... sort of retired...
