Adding sequential numbers for the selected features
4498
6
01-17-2024 11:41 AM
Labels (3)
YuvarajuDhananjay
I need sequential numbers(1,2,3...) for the selected features in the particular feild in attribute table, how to do it?
2 Solutions
Bud
Legendary Contributor
What kind of geodatabase?
If it's a mobile or enterprise geodatabase, it could be done in a SQL database view. And then you could join from the FC to the view and use the field calculator to populate the ID field in the FC.
Mobile geodatabase (SQLite):
select
    c.*,
    row_number() over (order by population_2021 desc) as sorted_id
from
    cities c
(File geodatabases don't have a row_number() function.)
If it's a file geodatabase (or any kind of geodatabase), you could use the Sort geoprocessing tool in conjunction with a join.
Like this:
(view in My Videos)
In hindsight, I could have joined on Objectid=OrigFID, instead of using my temp_unique_id field.
ArcGIS Pro 3.2.1
Raul
Check out this arcticle by ESRI Support, It's for ArcMap but it still works in pro! You can modify the python code to fit your needs :).
https://support.esri.com/en-us/knowledge-base/how-to-create-sequential-numbers-in-a-field-in-arcmap-...
If you want something more simple, calculate your field equal to the ObjectID
CodyPatterson
MVP Regular Contributor
YuvarajuDhananjay
this sequential number() is working based on OBJECTID, but I need the numbers without using OBJECTID in just sequential manner how my order is on the attribute table?
Bud
select
    c.*,
from
    cities c
Like this:
(view in My Videos)
ArcGIS Pro 3.2.1
BWetherill
You can create sequentially numbered attribute values in Excel and then copy/paste the whole column of values to the attribute table in Arc Pro.
