Adding Python package ArcGIS Pro
1674
09-24-2021 01:12 PM
MarkBowen
Hello!
We are trying to add the dltsolutions Python package in ArcPro after we cloned our environment with no luck. The package shows in the installed packages section, but the error attached is what we get after we try to load a project. Anyone else have this issue?
DanPatterson
MVP Esteemed Contributor
To rule out the obvious, was the folder there using Windows File Explorer?
and you were following this?
Install the Data Loading Tools—Get Started | ArcGIS Solutions
... sort of retired...
JoeBorgione
What version of ArcGIS Pro?  Have you tried using conda to install it?  I have little to no confidence in the Pro package manager...
That should just about do it....
