Adding multiple tracks to time animation
954
12-02-2022 06:51 AM
Srygl1sl
I am working on a map of the US with Alaska and Hawaii in separate map frames so that they can be shown in boxes at the bottom left corner of the map. Previously when I worked in ArcMap, I was able to create an animation that included tracks for each data frame, so that all of the states would animate over time in the layout view.
In ArcGIS Pro, I am not seeing a way to have multiple tracks in a single animation, let alone multiple tracks referencing multiple data frames.
I'd love some help getting an animation working that shows the data for all states animated over time in the layout view. Does anyone know how I can achieve this in ArcGIS Pro the way I was able to in ArcMap?
Thanks in advance!
DanPatterson
MVP Esteemed Contributor
not sure if this is what you want, there is a whole section in the help on animations
Manage multiple animations in a map—ArcGIS Pro | Documentation
it may help narrow down what is missing at least. There is also a Getting Started section
... sort of retired...
