Adding manual Points to failed Geocoded feature layer
3698
08-28-2022 08:53 PM
Anthony_R_McKay
I have passes a large table thorough the ArcGIS Pro Geocode Tool - which has left we with a number of locations not Geocoded.
So I now have a feature table with fields from the original table  which are not Geocoded.
I do not know how to add points manually without creating a new row and copying over the data tuple by tuple to the new row.
Is there a way to select the 'pointless' row in the table and add a point?
So far -
Selecting a row, then adding a point to the map just creates a new, empty, row.
If I try 'modify,' ArcGIS just laughs at me.
Any help would be appreciated.
Anthony_R_McKay
Thank you Scott,
That's exactly what I needed and such a clear explanation.
Very much appreciated,
Anthony
ShanaBritt
@Anthony_R_McKay Have you tried using what is described in step 4 in the Rematch tutorial for the unmatched addresses? Are you using a locator you created to geocode the locations?
https://pro.arcgis.com/en/pro-app/latest/help/data/geocoding/rematch-locations-converted-from-a-tabl...
Anthony_R_McKay
Thank you Shana,
That is quite useful for Geocoding, but I was wanting to know how to select an existing row in a table and simply add the position by placing a point on the map.
I imagine it's a common situation, where a table has been uploaded with a list of locations, and the points are added manually row by row.
It's probably child's play, but somehow I can't find the right buttons to press.
Thanks again,
Anthony
Scott_Harris
@Anthony_R_McKay
Try this:
  1. From the Edit tab on the ribbon, click Modify to open the Modify Features pane
  2. Open Replace Geometry tool
  3. Select the row in the attribute table for the point layer.
  4. Click Replace Point
  5. Click on the map where you want the point.
-Scott
Anthony_R_McKay
Thank you Scott,
Anthony
