Adding domain to ModelBuilder with the Add Field Tool
1412
03-07-2024 02:01 PM
Labels (2)
SpencerCox2023
Hello friends,
I am creating a tool that helps standardize a mapping procedure across my organization. To help make this as standard as possible I was trying to add domains into my ModelBuilder tool. To do this I added a few fields into the model using the "Add Field (multiple)" tool, but even though my current workspace has domains in it they are not appearing in the dropdown? If I open ArcCatalog in ArcPro I can see the domains that exist in this space, but they are not visible.
How do I point my "add domain" input box to the place where all my preset domains are held in my workspace/geodatabase?
Any help would be appreciated!
Robert_LeClair
Esri Esteemed Contributor
There is a GP tool called Assign Domain to Field you could use in your model that may work.
