addind excel in arcgis
1709
11-14-2021 02:31 PM
raoufbouamra
 when i add excel point i can't specify X OR y, any solution?
2 Solutions
LongDinh
Hi @raoufbouamra,
You should convert your xlsx file to a csv before adding it to ArcGIS Pro. You can use the this guide to create points from a table.
ArcGIS uses some keywords to automatically detect spatial field names (e.g. X, Y, Latitude etc...) in CSV, TEXT and GPX files. They can be found here.
Hope this helps!
DanPatterson
MVP Esteemed Contributor
If you intend to use excel, you should read the guiding principles to be aware of its limitations.
Work with Microsoft Excel files in ArcGIS Pro—ArcGIS Pro | Documentation
Also, in addition to the above, make sure you explicitly format your coordinate columns as double/float and ensure there are no blank cells in the sheet.
... sort of retired...
LongDinh
Hi @raoufbouamra,
Hope this helps!
raoufbouamra
thanks you so much my friend you saved me , i hope you will find only hapinessse in your life. take care
DanPatterson
