Add surface information stuck
1831
10-25-2022 12:18 PM
AngelaSchirck
I am trying to add surface info (z min, z max, z mean) to a polygon file.  I used the "Add Surface Information" in the spatial analyst tool box and have a DEM.  I have used this tool in the past with ArcPro 2.8.x and had no problem.  I have upgraded to ArcPro 3.0 and now this thing is stuck at 0% (see images).  I also tried this with just three polygons rather than my whole feature class, and still it stayed at 0% for over an hour.
Any idea why this is hanging up? Could it be a bug in 3.0?
Tags (1)
DanPatterson
MVP Esteemed Contributor
There are a number of bugs with the tool (some resolved).
You provide info on using fewer polygons, but what about the size of the input raster?
BUG-000126667: Unable to run the Add Surface Information tool on ra.. (esri.com)
others
Esri Support Search-Results
... sort of retired...
AngelaSchirck
Thanks, I did not make the raster smaller.  I can try that, but it's frustrating that it DID work with the same raster in the previous version.
