Add rasters via range request (http) from apache2 server
1324
02-15-2023 06:49 AM
PBircher
Is there a possibility to import rasters via range-http-requests based on apache?
With gdal the Metadata of the file is available in ArcGIS Pro. How can I add the raster to the map?
import arcpy
from osgeo import gdal
ds = r'/vsicurl/http://xx.xxx.xxx.xx:80/pixel_map.tif'
gdal.Info(ds)
Thank you and kind regards
Tags (3)
Luke_Pinner
MVP Regular Contributor
Make a VRT (virtual raster) that points to the url.
ds = gdal.OpenEx(tiff_url)
gdal.Translate("path/to/output.vrt", ds)
Or here's a python toolbox to do the same:
Add remote COG to ArcGIS Pro by URL - Add_COG.pyt
PBircher
Thank you. I will try it.
