Add Rasters To Mosaic Dataset using PlanetScope harmonized imagery
468
04-15-2026 10:36 AM
ColbyMitchell
Hello!
I'm working on a project for school and I want to do an NDVI change analysis to detect shrub growth up mountain slopes. I've done this tutorial: https://learn.arcgis.com/en/projects/monitor-forest-change-over-time/  that uses a multidimensional raster dataset and want to follow a similar workflow for my project.
In trying to create my own multidimensional raster, I'm running into some issues. I am using planetscope 3m resolution imagery that has been harmonized to be compared amongst each other and sentinal-2 images. I'm following this tutorial to make a multidimensional raster: https://www.youtube.com/watch?v=HFbTFTnsMWM
I'm struggling to add my raster data to a mosaic dataset with the associated metadata that will be used for the acquisition date of the photograph. I often get this error: "Error: 8004818c: No new mosaic dataset item was added" and I believe it is stemming from setting the raster type. When I set the raster type to PlanetScope or Sentinal-2, this error is typically my output. Sometimes I get this error as well: "160281: A requested row object could not be located" and I'm not really sure what to do about that.
If anyone has any advice on making a multidimensional raster from planetscope imagery, that would be really helpful, thank you!
JonM32
@ColbyMitchell
Have you tried adding the rasters to the mosaic dataset without choosing a raster type of Planet or Sentinal?
I would try the default Raster Dataset option. If it works, you may be able to bypass your issue doing this.
Hope this helps!
Cheers,
Jon
If this response helps or is the solution to your post, please consider marking it as a solution
JonM32
@ColbyMitchell
Check this blog post out - it may help understand what's going on for you. Looks like the same error code.
Tips for Working with Sentinel SAFE Products and M... - Esri Community
Cheers,
Jon
