Add chart to layer in map from Script Tool output
2244
11-15-2022 11:21 PM
NickMiddleton
Hi All,
Can an Arcpy Script Tool add a chart to a layer in a map?
The offending script will add the desired chart when the code is run from the Python Window as below:
import arcpy
import os
import datetime
lyrTemporalSamples = "samples1452temporal" #arcpy.GetParameterAsText(0)
inStationName =  "Vanesk Station" #arcpy.GetParameterAsText(1)
inBoreName = "All Bores" #arcpy.GetParameterAsText(2)
aprx = arcpy.mp.ArcGISProject("CURRENT")
map = aprx.listMaps("Halo")[0]
lyr = map.listLayers(lyrTemporalSamples)[0]
arcpy.env.addOutputsToMap = True
c = arcpy.Chart('TVCByDistance')
c.type = 'line'
c.dataSource = lyr
c.title = f"{inStationName}: Total Vegetative Cover By Distance from {inBoreName}"
c.yAxis.field = 'TVC'
c.yAxis.title = "% Total Vegetative Cover"
c.xAxis.field = 'distance'
c.xAxis.title = "Distance from a bore in metres (-9999 = no bore)"
c.line.aggregation = "MEAN"
c.line.splitCategory = "date_str"
c.addToLayer(lyr)
c.updateChart()
But when run it from a script tool with lines 5-7 above modified to the following the tool runs but doesn't add the chart:
lyrTemporalSamples = arcpy.GetParameterAsText(0)
inStationName =  arcpy.GetParameterAsText(1)
inBoreName = arcpy.GetParameterAsText(2)
Any help appreciated,
Nick
Tags (3)
NickMiddleton
Sorry for the disappointment but a restart of Pro has fixed my problem.
Hope the code might help someone and please reach out if you have questions.
Nick
NickMiddleton
Nick
Cristian_Galindo
I have no experience in the creation of "script tool", but in scripts with python and arcpy I do.
I would recommend try to make a old school debug technique:
In the line 8 set
print(lyrTemporalSamples)
at least in that way you will know if the value is passed through the parameters. also validate the
aprx
 variable, to know if the current map is taken.
ChristopherAllen
Hi @NickMiddleton ,
Thanks for the question! The preferred way of adding charts to an output layer or table in a tool is to set the  `charts` property of the output parameter (see the following documentation for more information).
To illustrate, I've created a simple script tool with the following parameters:
And the following tool code creates a new chart and adds it to the derived output layer by setting the `charts` property:
import arcpy
# capture the derived output layer parameter
output = arcpy.GetParameterInfo()[1]
# create the chart
chart = arcpy.charts.Bar(x='neighbourhood_group', aggregation='count')
# add chart to the output layer by setting the `charts` property on the parameter
output.charts = [chart]
I hope this helps, but please feel free to reach out if you have any additional questions.
Take care,
Chris
