3D models are end up broken when imported into Arcgis Pro
1459
03-05-2024 05:51 AM
KestutisPeseckas
Hi all,
I am strugling with importing 3D models into Arcgis Pro from Agisoft metashape. If I import tiled model it ends up perfectly fine, however if I do it with .obj or .dae files with texture they end up broken.
I run Arcgis on Acer Predator Hellios with  16 gb of RAM and Geforce RTX 2060, drivers updated.  This particular model has 10 000 faces. If I make texture size 1000 or 4000 same thing happens. If I import models without texture, they end up fine.
Did anyone encountered similar problem and what might be the issue?
JohanEA
Hi!
I have the exact same problem. Also photogrammetry-derived models (Metashape), also archaeology. Is this a bug? I have tried both geographic and local coordinates, mesh healing, all possible formats etc., but the same problem persists.
Sksonu35555
How have you Imported it
