3D features not showing though transparent layer in Global Scene
1226
03-25-2024 09:42 AM
DavidKidd2
I have a Global Scene that contains a 3D point and 3D line feature class, and a 2D polygon feature class.
The 2D polygon (palaeocontinents) are set to an elevation that intersects the 3D classes, but features are not visible through the 70% transparent polygons?
I am running Pro 3.2.1.
Dave
BrendanNewell
Hi @DavidKidd2, Couple of questions..
  • Can you share a screen shot of the Contents Pane?
  • What happens when you turn off the polygon, can you see the lines?
  • Do your lines have z values?
Going to be a cool looking map 🙂
Cheers
DavidKidd2
Hi Brendan
z is representing time, not that that matters.
Yes, the lines have z-values and are visible when the polygon is turned off.
Screenshot with content:
Interestingly, the lines are visible through a  fishnet-genertated 'disco timeball sphere. that has z set in the layer properties. Why is this not working for the palaeocontinent layer with z set is the same way?
