2.9 Display XY data, and Coordinate Table to Point Error Invalid SQL statement used
4264
01-08-2022 11:37 AM
MichelleWilliamsERM
I've tried all the normal tools to get this to work, but I think the underlining code is broken.
Please help.
Esri9.0 error coord tried float and double.pngEsri9.0 error coord tried float and double.png
Esri9.0 error coord tried Show XY from csv.pngEsri9.0 error coord tried Show XY from csv.png
Tags (3)
DanPatterson
why don't you show some of your table since I have used those tools many times.
Things that can go wrong... too many to list, but blank entries, wrong text encoding, punctuation within text,  ... symbols in text (like a degree symbol) etc etc etc.
Excel to table is pretty good, but will fail if a lot of rules aren't followed.  Excel to csv ... same thing.
I suspect your issue is within the table
... sort of retired...
DanPatterson
DD2, aka decimal degrees, 2 fields is the default,
your field type latfloat, should work
I would suggest
XY Table To Point (Data Management)—ArcGIS Pro | Documentation
to ensure nothing is wrong fundamentally with the data ot
Make XY Event Layer (Data Management)—ArcGIS Pro | Documentation
MichelleWilliamsERM
@DanPatterson, can you tell me that this tool works for you in Pro 2.9?
I've tried both suggestions, and I get the error when I try to open the attribute table.
Here's my workflow;
csv file to table to points (but I haven't gotten to the points yet).
I also tried importing the Excel table to points.
DanPatterson
MichelleWilliamsERM
Thank you everyone for you comments, I had a teammate try it on his 2.8 software and it broke, so with more digging we found a " in the header from another field.
