11.4 Converting from ArcGIS DataStore static data and integrating a SQL view with lat long fields
300
05-11-2026 01:07 PM
KennethPurcell
Hi, I have a ArcGIS webmap application in the enterprise (single mission deployment/one server) that currently uses static data and is updated by a .csv manual process . the ask is to automate the app by pointing  directly at the SQL view of 5-6 hundred records which contains lat and long fields and other info used in the app.  Is  this the best process  below to achieve this? Please comment on your best approach
1. Create a geodatabase
2. Register the SQL View in the Data Store
3. Point the geodatabase to the Data Store reference
4. Copy the existing app and rereference the layers (4) to the new geodatabase with the Copied layers
5.Test
Thanks!
