030116: The network was built, but with some errors
1993
03-30-2023 01:45 AM
SOTIRIOSTRIANTOS
We are moving slowly from ArcMap to ArcGIS Pro. For test purposes we tried to build a network dataset, with basic settings (no cost attributes except for Length, no restrictions, no descriptors).
Error details are at the attached txt file.
Can anyone "translate" the errors?
DanPatterson
MVP Esteemed Contributor
For reference
Network dataset build errors—ArcGIS Pro | Documentation
You have some multipart lines,  try the MultiPart to Singlepart tool to correct this one
... sort of retired...
DanPatterson
For reference
SOTIRIOSTRIANTOS
Thank you Dan
Can you give me a possible explanation how multiparts are created? My collegue claims that is a topology bug (created when using topology error inspector).
DanPatterson
Not sure but if you think you have found a possible bug, then reporting it to tech support would be useful
