Watershed tool should default to the extent of the flow direction layer not the pour points layer
922
09-21-2018 04:30 PM
Status: Open
ThomasDilts
Currently the watershed tool in Spatial Analyst will default the extent to the intersection of inputs, which is almost always the pour point layer.  That results in watersheds are truncated because of the spatial extent of the output raster.  It should almost always default the other way around, to the flow direction raster or use union of inputs so that watersheds don't get chopped off.  I propose that for this tool that the defaults are set to override the normal defaults.
