Warning when printing with Maplex Pause Labels Enabled
1691
08-02-2012 11:17 AM
Status: Closed
LisaDavidson1
The ability to Pause Labeling with Maplex is awesome. Sometimes I forget to turn the labels back on before I print a map. A warning prompt asking if you're sure you want to print the map without labels would be wickedly useful.
Thanks
Lisa
4 Comments
BlaneMoore
When exporting or printing a map, have the option to turn on a warning message box that will tell you if your labeling is paused or not.  There are many times where I pause the labeling while I perform corrections on a map, only to export/print the map and have forgotten that I paused the labels.  A simple warning that you can check on or off that would tell you that your labels are paused before the map is actually exported/printed would be nice.
JurajKrumpolec
All print/export issuses should be resolved in advance by pre-flight. Similar idea: Automatically detect potential issues before printing or exporting maps.
AubriOtis
Status changed to: Closed
Closing this ArcMap idea as ArcMap is being retired.
