Visual Scale Range Control
2433
04-29-2012 01:36 PM
Status: Under Consideration
JurajKrumpolec
Scale Range Slider in Layer Properties (General and Labels tabs).
0EM30000000D0n5
Interactive scale range settings directly in Labels tab to easily identify if labeling is scale dependent and simply change these settings with slider.
0EM30000000D0nA
Interactive scale range slider for each layer with scale depended visibility in Table Of Contents.
0EM30000000D0nF
Scale Range Manager in Table Of Contents for managing both layer and label visibility with interactive snapping and current map scale. Possibility to copy scale range settings between layers.
0EM30000000D0nK
4 Comments
emmornile1
Great concept.  In addition to copying from one layer to the other it would be good to lock the minimum of one layer to the maximum of another.  This would enable quick establishment of a smooth transition of features as scale changes.
TedCronin
Love the idea on the TOC.
ArcGISUser
This is a great idea!  I agree for each of your sample images.  Maybe have something like a Scale Manager, similar to the functionality of the Label Manager.
CoryWilliams
Looks like a great idea!
Can make life a lot easier when going through setting scales for every feature class in the map!
