Version Posting: select INDIVIDUAL changes to push through not ALL changes
1388
07-27-2015 07:24 AM
Status: Closed
Kara_Shindle
The ability to choose which "conflict" to accept as the true change (or none) is excellent, but there is no such ability to do so when there is no conflict - which is troublesome when an error is found by the DBA before a rec & post.
For instance, when you get a batch of changes to post from an editor, you must either post ALL changes or post NO changes. This is fine if all the changes are 100% correct, but unfortunately that is not always the case. It would be ideal to be able to select which changes to accept and post (highlight those you wish to post then click post) or select which you want to not post. That way the entire batch does not have to be 100% correct before a post, and you can send those which require reworked back to the editor but still get a majority of the updates pushed ASAP and not have to wait for the 5 out of 150 that are incorrect to be corrected first.
2 Comments
SSWoodward
This idea has been closed as a duplicate of the Data Management Idea linked below. Don't worry, you can still show your support by commenting and adding kudos to the open idea. Thanks for your contributions!
Link to open, duplicate Idea
SSWoodward
Status changed to: Closed
