Use full path references for data sources
718
07-23-2024 05:29 PM
Status: Open
RTPL_AU
Honored Contributor
Why is Pro using relative paths in some cases and then not finding a resource, when nothing has changed other than it is a new day?
Just go back to using full paths everywhere by default.
Yes - this is not the default gdb. No - the default gdb is used for other stuff. No - this data cannot go into the default gdb.
3 Comments
RTPL_AU
@yugulje  Can you elaborate?
All our data is on a mapped network drive.
From what I understand Esri is forcing relative references because it thinks everything should be in a single project folder/gdb near the aprx so that you can move it around and not loose connections.
This seems to break for various reasons and under various circumstances when you have data external to the default project folder/gdb.
In ArcMap you could specify full or relative paths to suit various circumstances. I just want feature parity.
RTPL_AU
It seems Pro 3.3 has issues navigating relative paths and will time-out or something leading to temporary raster layers failing almost every time a project is opened.
This path has not changed yet I have to edit the function chain every time and then fix the symbology every time.!
RTPL_AU
EVERY TIME WHEN YOU THINK "I JUST WANT TO QUICKLY........"
I used this yesterday and it worked after opening the project.  Edited some data, saved the project. Open it today and BANG.
Now I have to edit the function chains and redo the symbology because someone at Esri thought relative paths are the best thing for professional users yet forgot to ask the developers to do it properly!
THIS IS WASTING MY TIME AND IT IS TIME I CANNOT BILL TO CLIENTS!
The sources for the functions were selected from the dropdown in the RGP tools, and are located in a folder that is in the project or a dynamic function layer in the map.
